Old 01-10-2018, 09:48 PM   #10
Geof3
Originally Posted by Quadcammer View Post
You seemingly have no clue what you're talking about
Scroll down to the next pic.
You guys obviously didn't see the pic where the pully was sheared clean off the spool? I am fully aware the pully is a clutch type.
And where would "red dust" come from? Other than a rusted/worn bearing/surface? That pully is NOT normal. Sorry.
As mentioned, the pully is replaceable with a special tool. If there are no further signs of corrosion or otherwise, it should be fine. (though thstone's advice is spot on)
