Old 01-10-2018, 08:03 PM   #11
Htci
Issue Solved
During continued inspection of the issue, I made a couple findings including that one of the two screws holding one of the spark plug coils was loose although this did not improve the sound I was hearing, and also that as I backed the car onto ramps the sound got a bit louder. Days went by before I looked at the issue again. I decided I would change the oil to 0w-40 from 10w-40 to help the hydraulic lifters fill. I took the car off the ramps and let it warm up and the sound didn't return. As I learned more about the engine design, I learned what points I should be checking. I checked the valve cover on driver and passenger sides, at the points where the exhaust and intake cams reside. Both sides sounded the same with the mechanic's stethoscope I also checked the intake manifold on both sides and it sounded the same all over. I started checking the whole engine over with the stethoscope and couldn't find any unusual sounds. While I was in there I checked and cleaned the throttle body (it was basically clean) and also inspected the intake passages for excess oil from AOS but all was good. I had to take everything apart twice because I didn't clip the throttle body cable on completely and while I was warming up the car the throttle body actuator started making buzzing and electrical noises and the idle started to fluctuate erratically. Luckily I discovered this before driving off and it was an easy fix, and I didn't damage anything.
I have decided that my issue is resolved and here are my reasons and lessons:
-The weather had been very cold here at 30 degrees but recently warmed to the 60s. Apparently these cars are very sensitive to viscosity changes due to temperature.
-Even though the digital oil level gauge showed it to be at the lowest acceptable level, I did not bother to fill further. Apparently, these cars need to have oil level at least in center of acceptable range.
-The audio from my iPhone seems to have amplified the sounds because when I listen to the video now I don't hear that noise with my ear when standing next to the car. These car's lifters apparently make a good amount of noise but the noise I hear now seems to be normal lifter acoustics.
-Another issue I had like bumpy acceleration which I believe was due to tire imbalance, has also resolved itself as the weather has warmed. Apparently even the tires are temperature sensitive because I just took the car out for a spirited drive and all noises and bumpy ride is gone.
As I conclude this chapter in my Boxster ownership experience, I realize that Porsche owners, including me, are paranoid and over-reactive. If we take care of our cars well, I don't think there should be any reason to expect the worse (ie scored cylinder, IMS bearings, etc). And for me, in the worst case that I do have a catastrophic failure, there is so much information and support on this website that I'm ready to take on any issue. Like many others have said, quit worrying and drive.
2004 Boxster S 79K Miles
Htci is offline   Reply With Quote
