Old 01-09-2018, 08:09 PM   #13
Geof3
I'm surprised they just didn't use the same filter for both, I think they are the same height (3.404"). The only different seems to be the thread, and that the 51042 is a full flow filter with no bypass valve and max flow of 9-11 GPM flow, and the 51348 has a bypass valve and is rated for 7-9 GPMmax flow with the bypass set to open between 8-11 PSI.
It might help drive the oil to the IMS having a slightly lower pressure max? Good in theory anyway!
