Old 01-05-2018, 06:32 AM   #1
husker boxster
husker boxster's Avatar
It is possible you have a faulty AOS. Cheaper to change it out and see if that's the problem. Clean up the underside and see if that solves the problem. If it's the RMS, the trans will need to be pulled to replace the RMS.
So why did you post in the Cayman section?
1989 928 S4 5 spd - black
