Old 12-29-2017, 04:37 PM   #1
Brian in Tucson
Originally Posted by Walshie View Post
Hi everyone
The weather is bloody cold here in England but unfortunately I have to do some engine maintenance which obviously means opening the roof and folding the rear plastic window in.
I am carrying out this work in an unheated garage and I am worried about cracking the window or the stitching. Apart from trying to warm everything up, are there any good tips as it will probably be open most of the day
Walshie
How cold is "bloody cold?" What maintenance do you need to do that can't wait til warmer weather? You could use a space heater to warm it up to get it into service position, probably wouldn't work too well to get it out of service position, tho. To get it warm after you're done, open the garage door, start it up and run it to op. temp, then use a fan to blow the warm air into the area of the rear window.
2001 Boxster
2007 Toyota Highlander
