Old 12-26-2017, 10:56 AM   #25
356Guy
Originally Posted by Jamesp View Post
I used the technique from the pelican parts page. Pull out the lower vent tube and remove the electrical connector and two screws. The only hard part was getting my head under the clutch pedal so I could see the second screw. Grinding down a quarter inch drive straight blade screwdriver bit so it is teeny tiny is a must to get access.
What was the initial problem you had?
I just removed the switch this morning. I'm waiting for the new switch. I'm not 100% certain that the stiff turning of the key is caused by the switch. The key turns easier without the switch but it is still a little notchy at first turn. We'll see. Yes removal of the lower vent tube and upper AC duct makes removing the upper screw easier. There was red junk in the screw holes that had to be scraped out with a pick first. I had a 1/4" thumb ratchet with a socket and mini bit that worked nicely. Its one of those jobs that would be half the time the second time around.
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
356Guy is offline   Reply With Quote
