Old 12-24-2017, 09:56 AM   #1
P_Carfahrer
Pathological Tinkerer
I received my parts yesterday and the parts are very good. The rod ends are really nice and I am happy with them.
The supplier says they are the best rod ends you can buy and since it is on the internet it must be true. Right?
The 12mm spacers for the 12mm bolt head side are a couple degrees more limited than the 10mm high misalignment reducers and I haven't decided if I will leave them or build some without the limitation when I build the other spacers I need.
Don't mind the bolts as they were the only M12 and M10 stuff I had.
Car suspension is disassembled while I install the m030 springs/bars. When it is put back together I can get it loaded and get the needed spacer measurements and correct hardware.
Here are some pics.
P_Carfahrer is offline   Reply With Quote
