Old 12-23-2017, 08:29 PM   #18
cas951
Originally Posted by speedyspaghetti View Post
UPDATE:
So I picked up the car today - he said that the shocks were shot, tie rods in/out are shot, bump stops front are shop, and rear trailing arms are shot. He quoted me $3500 to do the 4 shocks/struts including labor/parts... seems a bit steep to me.
His suggested was that I sell the car.. he said it needed too much work and it wouldn't be worth it. He said that there is slight seeping from the RMS and in his opinion the clutch needs to be changed.
I'm not really sure where to go from here. I could do the tie rods - those seem simple enough - and then take it for an alignment and see if that does the trick. Otherwise, the guy kinda freaked me out. The car was running like a champ and it feels fine to me - just this infuriating vibration/shimmy through the steering when I drive.
Is it the same shop that did the inspection?
Which shop is this?
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
