Old 12-20-2017, 07:48 PM   #16
Geof3
Originally Posted by GTA_G20 View Post
FIRST STOP!!!!!!
Thank him for the diagnosis and get your work done elsewhere!!!!!!!!!!
Did nobody else read $200/hr labour? Ummmm no. Walk out. Dealer charges less
What he said, 100%.
While all of those things are maintenance items, they usually aren't an issue at your mileage. Struts might be tired, but probably serviceable.
Two other things, not even close to being mentioned, and VERY likely an issue with your shifting problem are the shifter itself and the motor mount. At your car's age I can almost 100% promise your motor mount is shot. I have an 02s with 58k, mine was toast. Very common. The shifter is an easy, relatively cheap fix that can literally transform your car. If your shifter feels sloppy, then it could use a swap as well.
