Old 12-20-2017, 05:50 PM   #13
Brian in Tucson
Originally Posted by speedyspaghetti View Post
Hey guys,
I posted on here a while ago about some vibrations/judders I was feeling through my steering wheel that a few shops had been unable to diagnose. I took the car (2002 Boxster S with 85k miles) to a highly recommended Porsche specialist here in the Bay Area and he did a thorough - and I mean painstakingly thorough - inspection of everything the car needs. He scared me a bit with his list - I don't think he's suggesting I do all of it, but he said he could find $15k (!!!!) worth of stuff to do.
1. He thinks vibration is caused by inner/outer tie rods and possibly strut mounts.
Replace the shocks, rebuild the struts (all one operation.)
2. Rear passenger strut is leaking, suggests replacing all 4
What has this got to do with feeling vibration thru the steering wheel?
3. Rear trailing arms need replacement according to him see #2
4. Clutch and/or shift cables need to be replaced - this is the one that has me a little miffed. I did notice that the clutch was starting to get a little hard to push in, but it does not slip at all. Shifting into 2nd has been a little jerky recently, but I figured that it might be something to do with not having had the clutch fluid changed and I have no service records from the previous owner indicating that the fluid was changed. I probably won't have him do this one since he didn't say it's an immediate necessity, but I also don't want to risk damaging the transmission itself.see #2
He mentioned other things like coil packs, spark plugs, and window regulators, brake pads and rotors, but I'm pretty confident that I can do those things myself.See #2
Thank you guys for any insight you can shed on any of the above items.
Ain't it nice spending other peoples money?:ah:
2001 Boxster
2007 Toyota Highlander
