Old 12-19-2017, 04:36 PM   #1
1998
P0453 fault code
Hello to all and happy holidays!!!!
Symptom: The check engine light was on and the gas gauge needle was stuck on empty.
I replaced the fuel sending unit with a new one. The check engine light remained on and the gas gauge needle remained stuck on empty after the replacement. It is obvious the fuel sending unit was not causing the check engine light to come on.
Using an ELM327 mini OBD today I got a P0453 fault code reading which references the Tank Pressure Sensor. Does anyone know how to fix it?
Thanks,
Robert
1998 is offline   Reply With Quote
