Old 12-17-2017, 07:03 AM   #11
stephen wilson
Originally Posted by Brian in Tucson View Post
I work under the Porsche with jackstands. The only way my car is coming off those suckers is if there's 7.0 earthquake or if an A-10 from the air base crashes into my house. Neither is likely in Tucson.
My ramps are made by Rhino and came from Autozone for about $45. They are plastic and I believe made from recycled Coke bottles and water bottles.
I have a bunch of floor jacks, but for doing a lot of work under the Boxster, I drive it up on the ramps and then use a 12 ton air jack from Harbor Freight. And then put it on my 6 ton jackstands. My worksurface is 6" concrete, very level, btw.
As mentioned, Always have a safety backup, whether it's a jack, or the tires shoved under the car. Any single device can fail, even a jack stand, though rare. Do you want to be under the car when you experience a fluke failure ?
