Old 12-16-2017, 07:03 AM   #12
Starter986
1998 Boxster Silver/Red
Originally Posted by Brian in Tucson View Post
If it doesn't do anything other than increase noise, why bother? Do you want your Porsche to sound like a ricer with a cheap CAI?
There are mods that will improve your car's performance that are easy and (relatively) cheap, like an under drive pulley or a spin on oil filter kit. Or even a magnetic drain plug.
"Cool Prius!"
- Nobody
You haven't seen my Prius.
Yes. A ricer. I'm looking at fart-can pipes on eBay, too. 2 footers straight out the back, 6 inch cans. 26HP gain.
That under-drive pulley I've looked at... but read somewhere that there's a small piece that has to be ground down in order for that pulley to fit. Is that correct? I've the pulley on my Pelican wishlist... but have held of purchasing it until I know it'll just bolt on... no extra shimming.
The spin on filter in on that list, too.
AOS is next on the list of parts I'm hoarding, for in the spring I'll replace the AOS, plugs, tubes, water pump, thermostat, etc.
Cheers!
1998 Porsche Boxster
