Old 12-14-2017, 11:21 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
Try disconnecting the battery, then putting the windows up/down. You will know if the "reset" worked if you have to hold the window button down to put the windows up/down the first time (one-touch shouldn't work the first time). If that is not it, it could be a faulty microswitch. I don't know if this will work, but you could also try raising and lower the windows by putting the key into the driver's door lock and holding it to the left and right (trust me it works). That may help determine if it the door lock is failing or if it is something else.
