Old 12-02-2017, 10:34 AM   #2
deathsled986
I think they'll fit. I'm running 18x11 et45 with a 13mm spacer so it's effectively et32. I've seen another member running 20x11 et52 with a 7mm spacer for an offset of et45. I think he was able to fit them with a higher offset because from pictures he looked to be running less negative camber than I am. It will be a relatively tight fit with with 10.5 et32 but I think it is very doable.
deathsled986 is offline   Reply With Quote
