Old 11-26-2017, 12:36 PM   #3
BoxsterSteve
still plays with cars...
BoxsterSteve's Avatar
Originally Posted by pinksnyper View Post
That looks great. For the novice painter, do you have a guide of sorts?
I started with 400 grit to sand off all the pebble finish, then went to 800 grit then 1000.
Then I laid on a coat of high build primer and sanded with 1500 grit. Did it again.
I sprayed light coats of base coat until the can was empty, then did the same with the catalyzed clear.
Six speed 2000 Boxster S
