Old 11-20-2017, 09:10 AM   #2
kk2002s
kk2002s's Avatar
Originally Posted by Lacostas View Post
So what shall we do about the SAI? Replace it and if so, how much ?
The SAI pump should only run aprox. 90 seconds on cold start up. Its a distinct sound different from the engine compartment fan.
The engine compartment fan should only come on with much heat(don't know the degree value) within the engine bay. You will feel the air flowing through the right side vent for the fan but not the SAI.
Not sure what tells the SAI to come on. I know If I crank the engine on a cold start but turn it off before it starts, my SAI will then not come on for that cold start
You certainly don't need to replace if it runs for the initial 90 seconds. They are expensive
Seal Grey
