Old 11-17-2017, 01:53 PM   #11
rastta
rastta's Avatar
Originally Posted by jsceash View Post
The split arms and shim are no different than solid arms except, when your frame side eccentric bolt bottoms out you add a shim and then you regain the adjustment of the eccentrics. I use a 3MM shim on the street and a 7MM shim on track. then adjust the toe link to get your toe back in.
I'm familiar with how they work. The issue is - when I'm looking to get an exact camber number - how do I know what shim to use? With a bolt - I can simply move it slightly to accurately dial in what I want. I guess if you have a variety of different sized shims this isn't a problem - but they aren't cheap.
rastta is offline   Reply With Quote
