Old 11-17-2017, 11:23 AM   #4
Lacostas
Originally Posted by rexcramer View Post
There are several drain holes to check. Front and back. A quick search will provide a lot of info, Youtube, etc. I suggest that you test them to verify they are flowing correctly. They are small diameter lines that could be clogged in the middle? Here is a couple with diagrams.
http://986forum.com/forums/boxster-general-discussions/37955-drain-holes.html
Boxster drain plugs
Thanks for the links. The second one seems to be for 987. I checked this https://sites.google.com/site/mikefocke2/_/rsrc/1259691725220/986drains-full.jpg
And I can't see any drain hole that is on the passenger side. If there was one there, it would explain the leak on the rear bottom carpet.
Lacostas is offline   Reply With Quote
