				letters
			There are a number of chemicals that will remove the old adhesive from the letters. I would start with brake clean or grease and wax remover since I always have those on hand. Body shop supply shops or auto parts stores should have emblem tape. I prefer the 3M brand. You can cut the tape into pieces the right size to adhere to the back of the letters. Clean the paint with grease and wax remover so the tape adhesive on the letters stick good. Use good auto body masking tape to pre-mark the placement for the letters. Remove the tape backing on the letters and stick them on the panel. Hope that helps you out. I used to work at a auto body shop in a previous life.
