Old 11-16-2017, 08:17 PM   #12
RobertKing
WRONG.
The release levers on a cable operated mechanical system are locked out when the drivers side door is closed.
I thought the lockout when the door is closed was due to the door panel blocking movement of the levers. If there is a microswitch that controls it, then it should not be possible to open either trunk when the battery is dead on those years.
RobertKing is offline   Reply With Quote
