Old 11-16-2017, 04:54 PM   #1
PaulE
For the track an underdrive pulley will help preserve your power steering pump and it won't have any negative effects on the street. You'll also get a couple extra horsepower through lower parasitic losses. If the flexible brake lines are original to the car you should consider stainless steel braided lines. If you are tall you may need the Brey-Krause rollbar extension. Ben006 makes a great modified short shifter using the eBay Chinese B&M knockoff and incorporating ball bearings, check out this thread in the DIY Project section. Also, some tracks require them regardless of the broomstick test. If you can find any part numbers on your suspension, you may be able to tell if they are ROW M030 pieces. I had the ROW M030 kit added to my 2003 S, and these were the part numbers in the kit I bought from Suncoast-
