Old 11-16-2017, 11:20 AM   #10
marck
marck's Avatar
WRONG.
The release levers on a cable operated mechanical system are locked out when the drivers side door is closed.
THERE IS AN ELECTRONIC SOLENOID THAT LOCKS BOTH LEVERS IN A MECHANICAL SYSTEM WHEN THE DRIVERS SIDE DOOR IS CLOSED.
The problem is one or more bad micro switches in the door.
WTF! oh well, I thought the door it's self was keeping the levers from being fully actuated. So can you remove maybe the window fuse and have that solenoid release? I'm certain I've had the battery disconnected and been able to release at least the rear trunk.
marck is offline   Reply With Quote
