Old 11-16-2017, 06:03 AM   #3
oldskool73
oldskool73's Avatar
does the window drop ok when you unlatch the top in the front? if so, it could well be the switch in the door not sending a signal that it's been opened (windows should drop when the door is opened or the top is unlatched).
I may be missing the point, but I don't think fixing the cable would help, that's for the window regulator and you say it's going up and down manually fine, so sounds like that's working ok.
oldskool73 is offline   Reply With Quote
