Old 11-13-2017, 06:35 PM   #10
Topless
Track rat
Topless's Avatar
Originally Posted by BoomerRoadie View Post
Hi.
I looked again closely at the carpet and trunk. Everything looks really good. But....I did notice that the "cup" section that the water cap and oil cap sit is often just a little wet. Plus the coolant cap is often a little wet too. AND, the cap was replaced way back in 2004 because the owner was complaining about the hot temp coolant light was going on. So, the dealer replaced the cap. My cap ends in 02. So, I'd say that's my first step here right? Change the cap to a newer version ending in 04?
Thoughts?
Change the cap, get a pressure test done, and flush the rads. Then get a proper coolant mix in there and you are good to go.
