Old 11-13-2017, 01:45 PM   #10
Topless
Track rat
Topless's Avatar
Originally Posted by BoomerRoadie View Post
Ok. I will take another look. Last check, the carpet was good a dry.
I have no idea what type of coolant was used before I added simple water. Maybe the maintenance records will show, but otherwise, no such luck knowing.
You definitely have a leak somewhere and you probably need to find it before it gets critical and trashes your motor. Also, distilled water is recommended instead of regular tap water . The minerals in tap water will cause galvanic corrosion in your cooling system which will become a nasty future problem.
Good luck!
