Old 10-21-2017, 04:13 PM   #5
jakeru
Originally Posted by Racer Boy View Post
In fact, our Boxsters DO have the tie rods in front of the axle on the front suspension. If you increase negative camber, you'll increase toe-out.
Thanks for the comment/correction, Racer! I just checked and sure enough, at the front of the car, you are indeed right! Tie rod ends in front of the steering axis.
At the rear of the vehicle, the situation is opposite, with the equivalent of the tie-rods (adjustable, control toe, but just not connected to any moving steering rack) being located behind the rear "steering axis".
The more I get to know this car, the more I continue to be impressed and fascinated by the "unique" mid-engine design (which seems to affect many different systems).
2001 Boxster
