Sorry, I am not quite following your wiring description...
The front and door speakers are wired through the factory amp. Prior owner installed an Alpine amp in the frunk and tapped into the front speaker wires for the inputs. This amp only powers the rear speakers.
I assume the dash and door wiring (both in and out) thru factory amp has not been changed. Do you mean that prior owner tapped into the outputs of factory amp for inputs to the Alpine? How are the connections made to the Alpine, via spliced RCA or screw terminals? Also, I assume the connection on the back of the CDR220 (socket C1) is still connected and has not been altered?
