Old 10-18-2017, 08:30 AM   #1
Ciao
Ciao's Avatar
I took out the tail light assembly today for a close look and discovered the loose metal track/trace has slots that may have come loose from the plastic tray. I re-insterted the slots located at the bulb location and ensure the other slots/notches were snug into the plastic part. I also closed the bulb slot slowly/carefully (with my fingers) and the bulb fit in much secure and tighter.
This simple solution may have solved the problem of the brake light bulb coming loose.
Thanks!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
