Old 10-17-2017, 01:15 PM   #1
LEJ
2001 Boxster 'S' 6 speed
2001 Boxster ‘S’ (6) speed transaxle, 3.2 engine
Orient Red exterior, black interior with Porsche logo stamped into the seat headrests
Xenon projection headlamps
White LED side marker lights
Current mileage 65,307
Upgraded tires and wheels prior to ownership 225/35/19 Front, 265/30/19 Rear
Falken Azenis tires date coded 25th week of 2015 (end of June 2015)
Relatively new convertible top with glass window. Installed prior to ownership
Upgraded rear bumper prior to ownership.
New water pump installed prior to ownership
Purchased June 9, 2016 with 62,104 miles on the odometer
Service performed as listed below is basically the 60,000 mile service.
The following is a list of all the service performed on the car since ownership
6-10-3016 Oil change and new filter at 62,120 miles on the odometer
6-11-16 New Serpentine Belt, 62,140 miles on the odometer
6-17-16 New gear oil,
New gas filter,
(6) new spark plugs
new spark plug tubes
62,171 on the odometer
6-22-16 LN Engineering IMS Kit,
New Pressure plate Clutch disk/throw out bearing,
New Coolant Tank,
New oil separator
New coolant. 62,212 miles on the odometer
6-22-2016 Oil change and new filter at 62,212 miles on the odometer
6-29-16 New front motor mount 62,601 miles on the odometer
6-30-16 New Pioneer 7200NEX double DIN stereo with Bluetooth, GPS and back up camera.
7-1-16 (2) new upstream O2 oxygen sensors 62,611 on the odometer
7-6-16 (2 new downstream O2 oxygen sensors 62,721 on the odometer
7-20-16 Turned all (4) rotors,
New front and rear Akebono brake pads,
New brake fluid
Wheel studs to replace wheel bolts
Ball bearing short shifter installed
63,075 on the odometer
Basically a 60,000 mile service
7-21-16 New climate control LCD screen
10-7-17 Oil Change 0-40 Mobil 1 synthetic ,
New oil filter
65,044 miles on odometer
10-9-2017 New 12 volt battery
Included if the negotiated price is above my reserve
Bentley repair book valued at $75.00,
Wayne Dempsey’s 101 projects for your Boxster (owner of Pelicanparts.com) valued at $23.00
Durametric code reader valued at $285.00
1 quart of Pentosin Dot 4 brake fluid valued at $12.00
1 quart of Pentosin CHF power steering fluid valued at $16.00
1 oil filter valued at $10.00
3 new spark plug seal tubes valued at $15.00
2 oil plug gaskets
Total of items included $436.00
Asking $11,750 will negotiate but if the price is below my reserve, the above listed "included" items will not be part of the deal.
Contact Larry at LJOWDY@AOL.COM
Current vehicle - -2001 Boxster S, (sadly all of the following cars are gone) 1973 911T with 3.2 engine, 2002 911, 1975 911S, 1971 911T, 1968 912
LEJ is offline   Reply With Quote
