Old 10-16-2017, 10:32 AM   #1
tolum
tolum's Avatar
Coulant pump & thermostat replacement time
Hi guys, discovered last week that my 2003 986 2.7l Boxster coolant pump was leaking and making a loud noise. Did remove it. It is the original one as the steel gasket is att to the motor. Did inspect it. The plastic impeller is intact but the bearing looks to be in bad shape. A new Porsche pump & a lower temp. thermostat are on their way. My question is can I still use the actual hose clamps or I should buy & install new one (Tridon type)?
Tks for your hep.
Thierry
2003 Boxster base
Upgrades so far: 4 Stalks installed,OBC, Cruise Control, Variable wipers, Rear speakers, Alpine CDEHD149BT deck, Alpine MRP-F250 4 ch. amplifier, Blaupunkt THb 200A pre-amplified subwoofer, XM radio integration, 997 shifter, front motor mount, LN Engineering IMS upgrade and much more.
tolum is offline   Reply With Quote
