Thread: Boxster codes
Old 10-15-2017, 02:29 PM   #2
thstone
Originally Posted by mrmopar View Post
Thanks for info and codes - any one any idea to fix this problem
Seems it could be a number of things
Or any one recommend some one who know
What there doing to fix for me - in Birmingham
Thanks again
2nd try...
Since there is more than one possible failure (wiring, failed ECU, electrical problem, crank position sensor, etc) that would cause these codes to be reported, you (or your mechanic) will need to do some diagnostic testing to determine the actual cause of the lack of signal between the ECU and the injectors.
Someone can tell you what part they replaced to correct these codes but that doesn't absolutely mean that your car will be repaired by replacing the same part.
