Old 10-11-2017, 06:24 PM   #5
KevinH1990
KevinH1990's Avatar
Originally Posted by 98Sixer View Post
Just replaced the stock CDR 220 Becker with a Pioneer Blue Tooth Set-up. Since I picked up the car, I now have the dreaded 1 Honk every time the car is locked or unlocked.
Can this somehow be related or does the timing of all this just make it seem that way?
It is most likely related. If you look at the CDR 220 you removed, there is a sticker on one side of the radio. (I think it is on the left side.) This matches up with an electrical connection. If the sticker isn't present, it will cause the anti-theft system to think the radio has been moved. Put a piece of electrical tape on your new radio in the same location as the sticker on the Becker unit. That should fix the problem.
See this thread for a more detailed explanation: http://986forum.com/forums/boxster-general-discussions/12517-aftermarket-cd-immobiliser.html
KevinH1990 is offline   Reply With Quote
