Old 10-09-2017, 05:43 PM   #1
xzyfsk
Do you have the holding tank full between the max and minimum lines? the light indicates low coolant. Did you open the burp valve between the coolant and oil fill when you were adding coolant? I did my water pump this past Sunday.
xzyfsk is offline   Reply With Quote
