Old 10-09-2017, 05:03 PM   #1
thom4782
thom4782's Avatar
Both points of view could be right. Check to see if the pump works. If it does, then look for a vacuum leak. My 01S had those same codes. I replaced the pump with a used one and they returned. Ultimately, a failed reservoir turned out to be the problem
