Old 10-08-2017, 08:45 PM   #3
lkchris
lkchris's Avatar
Originally Posted by gqllc007 View Post
I was told to keep the rpm as high as possible while around town?? Like 2nd gear at 4,000 rpm and not go into 3rd?? Not correct??
You were told wrong. Someone has taken advantage of your lack of experience.
Mine never sees 4K rpm almost ever unless I’m in some sort of race or just airing it out for fun.
Here’s something that’s true: in the history of internal combustion engines there’s never ever been one that required “keeping the rpms up.”
Obviously this assumes a driver that can recognize lugging and maybe even lugging induced pinging. Yes, I understand that a Formula 1 engine won’t idle at 900 rpm
If you’re not lugging it, any rpm above that is ok.
Finally, it’s something of a safety thing to have some acceleration in reserve, and with a manual transmission you have to create that. You should be able to tell how to do that and you certainly don’t need to look at your tachometer to do this. In fact you never need to look at your tachometer unless for some reason you’re running it out to redline.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
