Old 09-27-2017, 11:37 AM   #1
JOC IN IL
Originally Posted by PaulE View Post
If you remove the seat, I believe you have to disconnect the battery first. Otherwise when the seat is re-installed then your airbag light will be on, and you'll need someone with PWIS or Durametric or other appropriate code reader to get the light turned off. Of course having no power while the seat is out may make diagnosis more difficult.
Oh great, another problem arise from removing the seat. I'm not sure if the set has air bag, if it does i could see may trigger the srs light when the seat air bag connector is disconnected. I don't think the seat has air bag but I will have to look at the seat.
JOC IN IL is offline   Reply With Quote
