Old 09-27-2017, 08:31 AM   #1
steved0x
steved0x's Avatar
Originally Posted by eicheldp View Post
Thanks for the chart Steve. What should I assume that I would have installed on my car? The standard suspension for a 3.2L or the Sport M030 bar for a 3.2L?
If you look under your front trunk hood you should see a sticker with option codes, if you have the code 030 you have the sport suspension, and if not, you have the regular suspension.
If there is no sticker (for example there was a fender bender and the car got a new hood at some point) you could also look at the part number on the rear sway bar, it should be visible if you get down on the ground behind the car, and compare it with the part numbers on one of the sites with a parts lookup and diagrams.
