Old 09-22-2017, 03:23 AM   #1
TrumpyAl
Brake squeal won't go away.
OP fixed his problem several years ago I suspect. This is a 2012 thread, recently mined.
Warped rotors or otherwise misaligned aren't any more prone to squealing than straight ones in my experience.
Also, most 'warped' rotors are actually a buildup of pad material.
Chamfering the pads, around 30 degrees on both the leading and trailing edge is the most effective practice I've encountered.
(Speaking as a qualified mechanic, but I'm not a brake specialist)
I'm a huge fan of Hawk Performance Ceramic pads with the only downside being a little less initial bite when cold.
2001 Boxster S, TipTronic in Seal Grey aka "The Imp"
2001 TE50, ESS in (now) Grigio Titanio Matallizzato aka "The Golden child"
TrumpyAl is offline   Reply With Quote
