Old 09-11-2017, 12:57 PM   #3
Fodoposto
Originally Posted by ECU Doctors View Post
What! Really?
That fuse powers the entire unit. If the fuse was bad, none of the Immobilizer functions of the car should have been working. Strange.
I wasn't there to see what happened, but I can suspect that it was really a bad connection from the harness to the control unit.
While you were changing the fuse the connector "re sat" perfectly again getting everything to work properly.
Anywho...everything is working again. Good job!
Thanks for your response ECU Doc. You're probably right about the connector being reseated. However, while the door locks and dash button work, the key fob still does not.
Fodoposto is offline   Reply With Quote
