Old 09-05-2017, 06:54 AM   #2
ECU Doctors
ECU Doctors's Avatar
Originally Posted by Fodoposto View Post
After replacing the fuse in the immobilizer both doors will lock using the key and the inside cabin switch.
What! Really?
That fuse powers the entire unit. If the fuse was bad, none of the Immobilizer functions of the car should have been working. Strange.
I wasn't there to see what happened, but I can suspect that it was really a bad connection from the harness to the control unit.
While you were changing the fuse the connector "re sat" perfectly again getting everything to work properly.
Anywho...everything is working again. Good job!
ECU Doctors is offline   Reply With Quote
