Old 09-04-2017, 11:17 AM   #16
AZ986S
AZ986S's Avatar
First off I love AN hose and fittings. I also see that you changed the relief spring and piston. Looking at your pics from a fluid flow dynamics perspective my first thought was "wow those high pressure brass 90s from the adaptor are hugely restrictive". I'm pretty sure this was done to create a solid support for the hoses etc from the dynamics encountered during racing but unfortunately 90 degree fittings are basically a block wall to fluid flow. And this is the first and last thing the oil pump sees. Add to this the restricted id for high pressure and this is probably affecting fluid flow and ultimately pressure, (Decrease velocity ( the 90), increase pressure (pump discharge) creating a pressure drop across each 90 . Before jumping into the deep end and replacing parts, FWIW My .02 and an easy test is to remove the brass 90s, install 1/2" to -10 AN bushings into the adaptor, then a 90 deg -10 AN ell to your hose. The larger id and smooth radius of the AN fitting will be much less restrictive to fluid flow.
Thanks for the response.
I used the low profile brass 90 deg fittings for clearance. Initially I wanted to do just what you suggested (1/2 to -10 bushing then 90 deg -10 L), but this would have extended the L about 1 in below the oil sump plate. I will probably try this as I have the fittings, but I'm worried about shearing off those fittings and loosing oil at the track
I think I saw low profile AN "Ls" available, so that may help for clearance, but probably won't be as good as the smooth flowing standard "L".
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
