Old 09-03-2017, 02:18 PM   #11
robdelorenzo
ok. Thanks for your patience. Here are a few photos and what I just did this afternoon and what happened:
I had the rear of the car lifted overnight with the bleeder valve open. I started the car and ran it until the cooling fans came on. I looked in the drain hole and did not see any fluid moving, but I did stick a dry screwdriver in it and it came out wet.
I do not see any obvious cracks or leaks in or around the coolant tank.
It did start leaking from the overflow as soon as I started the car.
I felt the hose coming from the engine and it was warm. The hose coming from the thermostat was not, even once the cooling fans came on. If the thermostat is stuck closed would this cause the coolant in the engine to heat up enough to where it then is spit back into the overflow? It's a low temp thermostat from Pelican that was put in about 3 months ago that may have been damaged by the meltdown. What would the symptoms be? The temp gauge rises to 180 or so very rapidly and didn't used to do that before the meltdown. If the water pump impeller is melted or missing, would I have these same symptoms as well?
What I simply have not understood yet is why it starts dumping coolant from the overflow as soon as I start the engine from dead cold. In this case it sat all evening.
The new oil does have it purring as it should, so now I just need to understand what's needed to keep it cool.
I appreciate the help. It's not Tuesday yet and I really believe that with your help and experience I can get to the culprit logically and without going broke?
Thank you!
robdelorenzo is offline   Reply With Quote
