Old 08-16-2017, 11:01 AM   #2
truegearhead
truegearhead's Avatar
there's no code for low fuel pressure, but there is if the ecu can't hit the proper air/fuel mix. now, if it is only happening at high load then ecu isn't monitoring afr, so may be a fuel pressure thing that the ecu isn't detecting - reduced fuel pressure/flow doesn't become a problem until engine is demanding more fuel - crud in filter?
ecu reset is just disconnect battery for a bit.
I'm replacing the filter tonight so we'll see.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
