Old 08-16-2017, 07:26 AM   #1
The Radium King
The Radium King's Avatar
sound like car is in limp mode - does disconnecting maf have any effect (if not then car is not metering are and just using throttle position - limp mode)? could be low fuel pressure - pump or filter issues. should be a code regardless. did you reset ecu?
