Thread: A/C issues
Old 08-12-2017, 06:53 AM   #1
bwdz
The fan has to come on when you turn on the AC in any car as the condenser will not function efficiently unless there is air going across it and you can actually fry the compressor as it will create too much pressure. Having said that there are many reasons your ac will not come on. Low pressure, bad relay, bad switch, bad pressure sensor and the list goes on. Check refrigerant first with a gauge and go from there.
bwdz is offline   Reply With Quote
