Thread: Bent spoiler
Old 08-06-2017, 07:46 AM   #10
dsallean
Originally Posted by paulofto View Post
That definitely doesn't look right. It looks like the inner cable is extended out of the outer sheath. This could mean that it has actually come loose at the shifter end. When mine messed up the cable had popped off the linkage and it was an easy fix. This looks a little more involved.
The shifter end is all good. I removed the center console and checked everything. I did slide the metal end of the shifter cable at the transmission end back up and secured it with some Permatex RTV for now. Shifting fine thru all gears. But I think a new cable is next on the project list.
dsallean is offline   Reply With Quote
