Old 08-03-2017, 10:49 PM   #1
Crib
Crib
Originally Posted by lkchris View Post
Just in case ...
Many are mislead by the 101 Projects book that this mod requires removing steering wheel, etc.
In fact the lever for OBD bolts to the switch cluster and the entire switch cluster does not require replacement. So, if you can find a used switch cluster, just remove the OBD lever from it and fasten it to yours. The advantages being you have a logically marked switch plus you get all OBD functions.
I second that, the steering wheel does not need to come off in either case.
However i don't want the lever/stalk since i'm quite tall and I think they might be to close to my legs, and possibly break after some entry/exits.
Crib is offline   Reply With Quote
