The length under the hex nut of 996 oil pressure gauge and stock 986 oil pressure switch at passenger side were also short about 12.3mm(1/2 ").
AND the VDO temperature sensor installed was a bit longer about 2~3mm than the pressure one under the bottom line of its hex nut.
