Here's an option / example:
For the location of the senders
- Driver side of the engine block: There's an unused plug that I used for the temp sender
- Passanger side: Use a T to accommodate the existing pressure sender and add the new sender
Hardware example:
- Oil temp/pressure gauges (come with respective senders/sensors) - speedhut dot com
- T - Carquest 81640 (for metric M14 and 1/8 npt) **Your sender may differ.
Bellow is the passenger side of the engine - Pressure gauge senders, existing and new.
